These are the building blocks for IoT connected smart sensors. To quickly build a solution to your problem, grab the PUREmodules you need and assemble your solution today. There is no need to solder, breadboard, or wire anything. Once you have assembled what you need you can write your application how you want using your existing workflow or by modifying some sample code. We provide examples using Arduino environment to get you started.
