Usages Collection
A project log for Triggy - Sensor Node for Life Automation
A smart sensor Node to trigger an action on a smartphone each time a physical change is detected (temperature, displacement, click...)
vinchVinch 03/24/2018 at 13:550 Comments
At first glance it can be difficult to figure out what can be done with Triggy. However this project is really focused on usages and possibilities to offer a solution in a lot of embarrassing situations. Consequently, I started to create a booklet gathering use cases I've identified. It will take time to describe all of these use cases, but as a first step I've put the first 4 usages in the Triggy_Usages_1-4.pdf document (in the Files section). These usages are:
More to come. Good reading.
Rich text editor
