Hackaday.io Hackaday.io
Sign up Log in
Enigma QR Clock
An arduino and LCD display time in seconds using an optimized QR library by @ch00ftech and an optimized LCD library by @xark
arduino-enigmaArduino Enigma
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.7k views
0 comments
377 followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
4.7k
0
377
26
Team (1)
  • arduino-enigmaArduino Enigma
Join this project's team
  • hackaday article
  • c00ftech site
  • c00ftech QR generation code
  • Enigma QR Clock
  • Xark TFT library ported to Seeed Screens
  • Arduino Enigma Machine Simulator
  • Clear Acrylic Case
Software
ongoing project
QR clock arduino uno seeed adafruit LCD touchscreen
Related lists
Timepieces
Straightforward or Fully Obfuscated; How do you like to tell time?
Arduino Projects
Awesome projects using the popular Arduino platform
This project is submitted for
  • Tell Time Contest
This project was created on 07/24/2016 and last updated 4 years ago.
Description
Inspired by this article:
http://hackaday.com/2012/10/29/qr-clock-is-unreadable-by-humans-and-computers-alike/
A QR generation library was ported to the Arduino UNO and Seeed LCD touchscreen platform. Originally the generation time was 6 seconds, making the display of seconds impossible.
As @ch00ftech suggested, eliminating the search for the optimal QR mask and instead applying a fixed mask, drops the generation time to less than one second.
Using a fast TFT display library by @Xark allows seconds to be displayed. This library was modified to comply with the calling convention for @seeedstudio libraries, making it a drop in replacement in an existing sketch. By changing a compiler directive, this library can also control an @adafruit LCD.
As a further optimization, the last QR code generated is stored in a bitmap so only the pixels that change are painted.
Components
  • 1 × Arduino Uno
  • 1 × Seeed LCD v2.0 or Adafruit LCD
  • 1 × Laser cut case
Project Logs
Collapse
  • QR Code background can now be inverted.
    Arduino Enigma • 09/30/2016 at 10:58 • 0 comments
    It was reported that some (citation needed?) apps were unable to decode the default QR background. The i command was introduced to flip the color of the QR code. Updated code is at Github.
    https://github.com/arduinoenigma/EnigmaQRClock
    New Inverted view:
    Original view:
View project log
Log In/Sign up to comment
Sign up with Github
OR
There is an old-fashioned type of Persistence-Of-View display called Nipkow disk display. I made a desk clock using that principle.
Project Owner Contributor
Arduino Nipkow disk clock
joekutzjoekutz
Morse code with an ATMega328P and OLED display.
Arduino Morse Code Station
mario-gianotaMario Gianota
A comic trash project to add an LCD display to a microwave in the best traditions of quick-and-dirty diy
Hacking a mircrowave
daniilDaniil
A retro watch, based around the HP QDSP-6064 Bubble display and on the Arduino platform
Retro|Watch
rafael-riberRafael Riber
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Enigma QR Clock", please tell us the reason.
Send message
Remove Member
