Hackaday.io Hackaday.io
Sign up Log in
Enigma QR Clock
An arduino and LCD display time in seconds using an optimized QR library by @ch00ftech and an optimized LCD library by @xark
arduino-enigmaArduino Enigma
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.7k views
0 comments
376 followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
4.7k
0
376
26
Team (1)
  • arduino-enigmaArduino Enigma
Join this project's team
  • hackaday article
  • c00ftech site
  • c00ftech QR generation code
  • Enigma QR Clock
  • Xark TFT library ported to Seeed Screens
  • Arduino Enigma Machine Simulator
  • Clear Acrylic Case
Software
ongoing project
QR clock arduino uno seeed adafruit LCD touchscreen
Related lists
Timepieces
Straightforward or Fully Obfuscated; How do you like to tell time?
Arduino Projects
Awesome projects using the popular Arduino platform
This project is submitted for
  • Tell Time Contest
This project was created on 07/24/2016 and last updated 4 years ago.
Description
Inspired by this article:
http://hackaday.com/2012/10/29/qr-clock-is-unreadable-by-humans-and-computers-alike/
A QR generation library was ported to the Arduino UNO and Seeed LCD touchscreen platform. Originally the generation time was 6 seconds, making the display of seconds impossible.
As @ch00ftech suggested, eliminating the search for the optimal QR mask and instead applying a fixed mask, drops the generation time to less than one second.
Using a fast TFT display library by @Xark allows seconds to be displayed. This library was modified to comply with the calling convention for @seeedstudio libraries, making it a drop in replacement in an existing sketch. By changing a compiler directive, this library can also control an @adafruit LCD.
As a further optimization, the last QR code generated is stored in a bitmap so only the pixels that change are painted.
Components
  • 1 × Arduino Uno
  • 1 × Seeed LCD v2.0 or Adafruit LCD
  • 1 × Laser cut case
Project Logs
Collapse
  • QR Code background can now be inverted.
    Arduino Enigma • 09/30/2016 at 10:58 • 0 comments
    It was reported that some (citation needed?) apps were unable to decode the default QR background. The i command was introduced to flip the color of the QR code. Updated code is at Github.
    https://github.com/arduinoenigma/EnigmaQRClock
    New Inverted view:
    Original view:
View project log
Log In/Sign up to comment
Sign up with Github
OR
My base code for scientific projects on Arduino DUE with easily scalable "scope" display, cursor, and working SD.
Project Owner Contributor
Scalable Scope Display, Arduino DUE platform
peter-wardpeter ward
A retro watch, based around the HP QDSP-6064 Bubble display and on the Arduino platform
Retro|Watch
rafael-riberRafael Riber
A 4.3″ touch TFT LCD, an Arduino DUE and some lines of code are the ingredients of this weekend project.
TIC TAC TOE WITH ARDUINO DUE AND 4.3″ TFT
manosManos
There is an old-fashioned type of Persistence-Of-View display called Nipkow disk display. I made a desk clock using that principle.
Arduino Nipkow disk clock
joekutzjoekutz
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Enigma QR Clock", please tell us the reason.
Send message
Remove Member
