Stage one: designing the quad body
A project log for Unique mini quadcopter
fully designed mini quadcopter for special applications unique body, microcontroller and flight controller software
bennyBenny • 07/25/2016 at 09:22•0 Comments
first step: I have started to detrmine the size of the drone base on all the component I am planning to use and its porpose. based on then i have also designed univesal motor mount for the motor range I could use I that size and weigth scalse.
