An open & automated countertop aeroponic factory for herbs and other edible small plants
Quick update. The current experiment is
Photo evidence:
I came back to the office this morning to some unhappy plants:
They obviously didn't get enough moisture during the night. I can see from looking at the log from the Pi that the humidity was reported as pretty much constant so no misting was done, which is bad:
What you're seeing here is the humidity reported by the DHT22 & the last 3 readings. I'm using an average because I've seem some spurious outlying numbers reported (going from 90%+ to 43% on within seconds), and the correct way to handle this is to discard those number and use an estimate instead, but that code doesn't exist yet.
I also suspect that the root systems of the plants are simply not developed enough to absorb sufficient moisture from the mist since they developed in soil, and I should start with seedlings instead.
Next steps:
Today I received the timers that I'm using for the grow lights, so I've installed v1 on my test shelves and put some basil in! I've put the timer on so the grow light is on for 12hrs per day (no idea what it should be), and the aeroponic mister detects humidity below a threshold and will activate the fan & mister.
Currently I'm a bit blind as to what the best parameters should be for humidity and lighting, but discovering these things is the whole point of the experiment!
