The Hackaday.io Randomizer
Like Russian Roulette, except somewhat less dangerous.
Click the link below to be taken to a random Hackaday.io project.
https://greg-kennedy.com/RandomIO
How it works: IO links have a project name in the URL, but it also works if you remove everything except the ID number.
So, a Perl script using WWW::Mechanize first visits the Projects page "sorted by date" and identifies the highest ID in use. Then, it repeatedly chooses a random number and tries a GET to see if that page exists. If no 404 is returned, it gives the URL back.
A simple PHP wrapper calls the Perl script and returns the URL in a Location: header.
Amar wrote 10/30/2017 at 17:30 • point
Would hackaday's API for GET /projects be easier for this?  https://dev.hackaday.io/doc/api/get-projects
davedarko wrote 10/30/2017 at 11:12 • point
Hackaday.io just shared that on twitter, but the link seems to be frozen? do nothing?
Stephen wrote 08/21/2016 at 07:34 • point
Wheel go round and round long time. No work ever. Sorry I've been talking to Ebay sellers too much today. B-)
RoGeorge wrote 08/19/2016 at 23:20 • point
Bookmarked!
I like this randomizer very much. Do you think it would be good to filter out not only the missing projects, but the projects without a picture too?
Arya wrote 08/09/2016 at 19:27 • point
Seems down to me now
davedarko wrote 08/01/2016 at 09:36 • point
Non existing / deleted projects throw a 404, right? Nice. I had a javascript randomizer on the hackaday logo once, but this is way better.
I got here from: http://hackaday.com/2016/07/31/hackaday-links-july-30-2016/
Greg Kennedy wrote 08/01/2016 at 16:09 • point
Yes - each potential is checked for HTTP header errors before returning to the client.  Source is available!  Check the left sidebar (links section).
One interesting thing about this is that apparently the same IDs are used for Project and Hackerspaces.  So, sometimes you get passed to a random hackerspace, and sometimes a random project.
PointyOintment wrote 08/02/2016 at 05:08 • point
Lists (and I think other content types) as well. First thing it gave me was https://hackaday.io/list/6021-weather-display-projects
