With the table capable to cut across the width of the material (48 inches), a program was created to act as the final cut to remove the completely cut material from the main sheet.
G21 G54 G90X-665Y10 G0Z1.0 G38.2Z-300F1000 G92Z-18 G90G0Z1 M3S10000 G4P1.2 G1Z1.0F1000.0 G1Y-1210.0F2500.0 M05 G0Z10.0 M30This code was ran after homing the machine ($H) and resetting G54 location5 mm from the edge of the homing resting location. It made a clean cut, except the beginning.
I had forgotten about the delay to fire and will have to implement a primary cut that is near the cut line, but not on it.
