As there have been a few cuts under the plasma tables belts, it is time to get the cutting experiences documented.
Speed changes (I think, it was a while ago that these pictures were taken)
Go too slow and overcut happens:
Go a faster speed and things look better:
Dragging a torch along flat steel causes the arc to go out. The loss of arc path is highlighted in yellow:
Having a non perpendicular head can cause splatter/incomplete cut in certain directions:
To be continued. . .
