Well I am going to throw away those cheap Chinese PCB boards away. One mistake and the tracks lift. Horrible! But I did get the board finished and tested:
A respectable 42 ns propagation delay but not that much better than a BC548B (64 ns). It falls short of my expectation of 15 ns (as reported by others).
I think the base drain resistor probably needs adjustment. However, I don't think the board will survive a couple of rounds of resistor swaps.
I think I would be better off soldering the link wires (the rows of holes above the pin header) to convert the board into a D-Latch/Flip-Flop and testing that and then make a new board out of a better quality PCB.
In case your wondering how this fits in the with TTL: the above board is currently equivalent to two 74LS10. After the link wires are added it is 1/2 a 74LS74.
AlanX
agp.cooper
