The last few days I worked on the android apps. With it you can control the frequency and phase output of the DDS Generator. In the Tool section you can activate or deactivate both leds.
The Code is licensed under the Apache License 2.0. You can find the source here: Github . Under Releases you can find an signed APK of the app.
Here are some screenshots:
Jan B.
