I needed to make a current vs tension graph of the leds I ordered, but unfortunately the cheap hook I had did not do a great job on so tiny and light component.
Fortunately, I ended up with a solution I like.
See it there if you want: http://hackaday.io/project/1300-Easy-breadbording-of-0603-SMD-components
