This is a pizza oven controller which will use an ESP8266 along with a thermocouple and a MAX6675 to send temperature information to a MQTT broker. The long term goal will to add motor controls to also control the flame height to maintain the proper temperature.
Components
1×
NodeMcu ESP8266 ESP-12E WIFI Development Board
NodeMcu ESP8266 board flashed from Arduion IDE
Could you please share the actual sch & firmware for this project . I want to build & try this for m Pizza oven also, since already have all these required parts in hand. Thanks
haha! hopefully it wont be for a Darwin Award. But, I think that the simplest application is an alarm that will let me know when temperature goes too high/low. The next step would be to rig a motor against the flame control (though, that is something that I should monitor). There are beer brewing systems that do this very affectively though.
I tested the temperature monitoring on both my pizza oven and a solar oven that I have and the device did great! I think one of the best things is with the solar oven. I can set an alarm when the temperature starts to go down letting me know that the focal point of the sun has moved and I have to reposition the solar oven. that is very handy so I don't have to continually watch the oven and its position to the sun.
Hi Brian,
