Hackaday.io Hackaday.io
Sign up Log in
ESP8266/MQTT Pizza Oven Controller
brian-whartonBrian Wharton
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.6k views
3 comments
13 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 3
View Gallery
4.6k
3
13
8
Team (1)
  • brian-whartonBrian Wharton
Join this project's team
  • Arduino MQTT Thermal Couple
hardware
ongoing project
mqtt ESP8266
This project was created on 07/29/2016 and last updated 10 years ago.
Description
This is a pizza oven controller which will use an ESP8266 along with a thermocouple and a MAX6675 to send temperature information to a MQTT broker. The long term goal will to add motor controls to also control the flame height to maintain the proper temperature.
Components
  • 1 × NodeMcu ESP8266 ESP-12E WIFI Development Board NodeMcu ESP8266 board flashed from Arduion IDE
  • 1 × MAX6675 K-thermocouple module temperature sensor https://www.amazon.com/gp/product/B0100A7SS6/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
  • 1 × Thermocouple lead Was included with purchase of MAX6675
  • 1 × SSD1306 OLED Module http://www.banggood.com/0_96-Inch-4Pin-White-IIC-I2C-OLED-Display-Module-12864-LED-For-Arduino-p-958196.html
Project Logs
Collapse
  • Solar Oven Picture
    Brian Wharton • 08/01/2016 at 17:37 • 0 comments
    Added pic of use in a solar oven.
  • Added pics showing use in solar oven and pizza oven
    Brian Wharton • 07/31/2016 at 23:28 • 0 comments
    Added pics on testing it out in the pizza oven and solar oven.
  • Added OLED Output on Device
    Brian Wharton • 07/30/2016 at 16:13 • 0 comments
    Added OLED Output to the device for local viewing of temp. (See updated code on GitHub)
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
ijaved wrote 11/17/2024 at 08:20 • point
Hi Brian,
Could you please share the actual sch & firmware for this project . I want to build & try this for m Pizza oven also, since already have all these required parts in hand. Thanks
PuceBaboon wrote 08/01/2016 at 00:27 • point
Flammable gas, ESP8266 and pizza ...Hmmm, methinks you've done some research on the target group for the HAD prize.  :-)
Brian Wharton wrote 08/01/2016 at 17:34 • point
haha!  hopefully it wont be for a Darwin Award.  But, I think that the simplest application is an alarm that will let me know when temperature goes too high/low.  The next step would be to rig a motor against the flame control (though, that is something that I should monitor).  There are beer brewing systems that do this very affectively though.
I tested the temperature monitoring on both my pizza oven and a solar oven that I have and the device did great!  I think one of the best things is with the solar oven.  I can set an alarm when the temperature starts to go down letting me know that the focal point of the sun has moved and I have to reposition the solar oven.  that is very handy so I don't have to continually watch the oven and its position to the sun.
Bluetooth LE temperature controller for the 946C electronic hot plate
Project Owner Contributor
Reflow946
arnauddurandarnaud.durand
A device to use a NES gamepad, Zapper or Power Pad as a Bluetooth (BLE) controller with low latency.
NES Controller to Bluetooth adaptor
thomas-grechThomas Grech
Use your smartphone as a remote controller, no internet or app required! Just by browsing.
ESP8266 WiFi Tank Remote Controller
giulioGiulio
Replace the bimetallic thermostat with a few microcontroller based thermostats to control the combi boiler.
Multi Zone Wireless Thermostat
jose-maria-rodriguez-saezJose Maria Rodriguez Saez
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ESP8266/MQTT Pizza Oven Controller", please tell us the reason.
Send message
Remove Member
