Now that I have the LCD nicely fitted in the printer it is the turn of the RAMPS/Arduino board(s).
I printed an adapter (the model can be found in the files section and it is using the same printer! ):
It is meant to fit where the old board used to be (but is much smaller):
The board inside the adapter(with the help of hot glue):
And all inside the printer:
And with the lid close(this marks the end of this conversion!):
Uriel Katz
