Collecting, documenting, and sharing everyone else's unused PCBs
If you have board(s) to donate to the Hackaday Gallery, request to be added to this project. From there, i'll message you with further instructions
Interesting! I was planning to use a white background with some careful lighting to document the PCBs, but it makes sense to use a scanner to get a high resolution, quality picture. I'll have to dig out my old scanner and windows XP box and give it a try.
If you have those old (non-contact type) scanners, you can even scan populated PCB. This one was scanned too. :)
CCD scanners are still made; it's just most of the cheaper ones that are CIS-based. I saw something recently about this—I think it might have been related to that bury-a-scanner-in-the-ground-to-image-underground-activity project posted on the blog not long ago.
https://hackaday.io/project/1347-fpga-computereval-board/log/6562-blank-pcb-scans-large-files
