Setup Transmission on the Omega's USB storage, and wirelessly share your downloads.
Because of the Omega's limited storage, we'll need an
external drive in which to place our downloads. Follow these commands on
your Omega Console to mount the drive.
1-A) Plug in the USB Storage
1-B) Usually, it will get mapped to the sda1 device. Double check the mapping:
ls /dev/sda*
1-C) Create a mount point directory
mkdir /mnt/sda1
1-D) Mount the drive, using 'mount <device> <mount point>'. For example:mount /dev/sda1 /mnt/sda1/
The storage can now be accessed at /mnt/sda1
1-E) To safely remove the drive, use 'umount <mount point>'. For example:
umount /mnt/sda1/
For the purposes of this guide, let's assume the USB device was mounted to /mnt/sda1
For more on using USB storage (including automated mounting):
https://wiki.onion.io/Tutorials/Using-USB-Storage
Because of the Omega's limited memory, we need to setup a swap file on the USB storage to extend the available memory. Follow these commands on your Omega Console to setup the swap file.
2-A) Install the required package
opkg update
opkg install swap-utils
2-B) Use the dd utility to create the file that will become the swap file.
The dd utility can be dangerous if used incorrectly
dd if=/dev/zero of=/mnt/sda1/swap.page bs=1M count=256
2-C) Setup the swap file as a swap area
mkswap /mnt/sda1/swap.pageRunning the free command will show you that nothing has changed yet
2-D) Activate the swap file
swapon /mnt/sda1/swap.pageRunning the free command again will show that the swap row is populated
For more on using swap files (including automated swapping):
https://wiki.onion.io/Tutorials/Extending-RAM-with-a-swap-file
We'll need a client to download files via BitTorrent;
Transmission works well on OpenWRT so let's install the daemon as well
as the web interface packages:
opkg update
opkg install transmission-daemon transmission-web
