In this guide, we will use the Omega to retrieve and display stock prices.
plain - 117.00 bytes - 08/02/2016 at 17:19
py - 440.00 bytes - 08/02/2016 at 17:19
Connect your Omega, Expansion Dock, and OLED Expansion as shown.
You will need to setup wifi so that we can install python and fetch stock data from google:
wifisetup
Follow the instructions and give the Omega access to your wifi network.
We will need to install the full version of Python so that we have access to some libraries necessary for webscraping:
opkg update opkg install python
You may or may not need to clear some space on your Omega for the installation. If you are doing this right out of the box, you should be fine.
View all 9 instructions
Onion.io
Mauro Riva
Øystein
sheikh
Yes, delete it Cancel
You are about to report the project "Onion Omega Stock Ticker", please tell us the reason.
