First boards
A project log for Modders Friend
Tiny Internal USB-Gamepad adapter for case modders.
danjovicdanjovic 11/27/2016 at 15:130 Comments
I have made two boards at home for this project. One is for the PTH version with attiny85.
The other board is two sided and it required a lot of patience to make the layers match as well as the drilling on the vias. The drill bit has only 0.6mm!
Rich text editor
