Mechanical
- Cut Openbeam for frame
- Build frame
- Buy castor wheels for prototype($8 *2)
- Design main compartment for holding batteries and ARM SOC.
Electrical
- Finish design and layout of nucleo_f767zi shield
- Order pcbs from dirtypcbs (10$ * 2)
- Build pcbs
- Order Nvidia X1 $599(-$300 student coupon) $299
- Optional - Research camera options compatible with X1(speicalized camera bus)
Software
- Port FreeRTPS to nucleo
- Implement state machine for commutation and hall effect sensors
- Implement Set Speed and Get Speed services for ROS
- Basic navigation interface - off the shelf drone software if applicable
- Optional - camera interface and SLAM algorithm
The X1 will be the main ROS node and I will use a mini-Ethernet hub to connect the X1 to the motor controller(s).
Command and control will be done through the X1 and eventuallyy some sort of SLAM with cheaper off the shelf cameras.
Thanks for the question.
How are you planning to integrate the X1 ?
