Ok guys. So im plan to make this as easy as possible. So i need a web developer to help me.
I want to make something like this for my water sensors.
So if anybody is willing to contribute please contact me. Custom all in one boards are in production and lets see what comes from this.
Well i plan to make it easy to deploy as much as possible. im making a pcb so anyone can make it by just buying a few components all open source. site would need to have some sort of form to add info about the data point and when added it gives you api that you add to your arduino code. If you can help with the server side thing i can do all the arduino stuff.
I also have a dedicated server.
Hi Marin, created a map view as in http://www.uradmonitor.com/ can be done easily. The gps point to the device would need to be manually mapped. would be able to assist, how many devices are you planning to monitor
