Last Christmas, my sister received a set of Samsung Level U wireless headphones.
She didn't like them, and so she gave them to me. I liked the convenience of the wireless headphones, but didn't like the earbuds that came with them. Just swapping out the earbuds would have been to easy, so I decided to replace them with a headphone jack.
2
Step 2
My first problem was trying to get the set apart. (If any Samsung engineers are reading this, next time please use more screws and less glue.) I was able to remove one of the side stems by sliding a razor blade under the rubber and carefully prying the rubber off the mount. With the side stem removed, I was able to pry the rest of the set apart.
3
Step 3
Here is what I found inside.
For the sharp of eye, yes I did accidentally disconnect the right headphone wire when I was prying open the case.
I think that this strip of wire is the antenna for the Bluetooth module. it contacts the spring on the left hand board.
The jack came out of a MP3 player that broke. Despite already being small, I had to scrape away much of the plastic on the jack to make it fit. You can sort of see where I scraped the plastic in some of the pictures.
Good, quick write-up! I've done similar with bluetooth headphones, which gives you a lot more open space inside, usually. I should get some of those smaller headphone jacks like you used...
