Initial Build (Just getting Started)
A project log for Serenity - Web Based Automation Framework
A user-friendly and customizable intranet of things framework that makes home automation a breeze. Automate your home with no code!
cfaCFA • 08/10/2016 at 02:09•0 Comments
Our main focus right now is the trigger-action capabilities with the different arduino sensors. So far we have a few sensors working as triggers and relays and Leds firing as out actions.
Completed:
-Json configuration Files
- Trigger - Action Code
- A basic UI
To Do:
-Access Control
-Add more hardware compatibility
-Better Looking UI
-Configurable Home Page
-Plugin Support
-Configurable general settings
This video is demonstrating the trigger action functionality of HAAC-IoT. In the video it is configured with 2 triggers, each a get request relying on the parameter "val". Those triggers have corresponding actions which are configured to open and close the relay in the video. An easy way to create an Iot Device with no code!
In the next update we will show the easy to use user interface for configuring arduino pins, triggers, and actions!
