Preview Video!
A Fresh Approach to Richard Landon's Design using Delrin and a Laser Cutter
Preview Video!
With the second controller built, I connected it to the tentacle last night and gave it a whirl. It worked!
It looks like I'm going to need a rigid mounting fixture to prevent the base from twisting. I also had to be very particular with the arrangement of the cable housings (extension spring in this case) such that they don't cinch or rub against each other while the tentacle moves. With the proper base fixture, I can probably solve both of these issues to make mounting a snap.
I've been trying to come up with a cheap alternative to those hubs, though. They're like $8 each!
Especially a solution that can be found locally or on AliExpress instead of McMaster.
Videos worked fine on mobile for me. Like your design. Was working on something similar for a project of my own but yours is much more minimalistic compared and is just the right amount of creepy.
...no, for me its simplely doesn't work
