Testbed for Motion Control
The problems of working directly on the Dalek are:
- It is too big to bring inside (it does not fit through the normal door frame)
- It is a headache working on as everything is inside.
- The skate wheels don't have a lot of traction and the Dalek gets bogged.
- It drains the battery after about 30 minutes.
I really need to upgrade the wheels but that is another project in itself.
The solution is a testbed for the motion control (note the worried dog):
And the underside:
The steppers are 12v so no over current risk with the 12v power supply.
I would like to uses these components on the Dalek but the motor axles and wheels would probably bend or break.
So all I need to do now is mount the Arduino, motor controller and battery pack.
AlanX
