The “Crivit Sports” wrist watch HRM (Heart Rate Monitor)
This is a wrist watch that can also display the heart rate BPM (Beats Per Minute).
The complete specs and the user manual can be found at http://www.lidl-service.com/cps/rde/xchg/SID-648946E8-5F850FDD/lsp/hs.xsl/product.html?id=47039228
The heart beats are detected by a chest strap included with the watch.
The chest strap have two conductive rubber pads that senses the electrical signals produced by the heart beats. No contact gel is required for the rubber pads.
The link between the chest strap and the wrist watch is wireless, by an RF (Radio Frequency) signal.
Missing features
Being a very cheap item, it does not have any kind of connectivity, it can not log data, and it can not make charts. It
would have been way more interesting to be able to see a ECG
(ElectroCardioGram) or a BPM chart for the whole day. Could it be
possible?
I couldn't find any online technical documentation about this 'Crivit Sports' model.
Reverse engineering the RF signal
by simply clipping the oscilloscope GND (GrouND) wire alligator to the
tip of the probe, and around the chest strap transmitter.
This is the signal received from the chest belt HRM for a constant
heart rate of 100 BPM. The RF carrier is at 110 kHz, 100% AM (Amplitude
Modulated) by a digital signal.
By looking at the received signal for various heart rates, it turns out that the BPM rate is computed by the chest wrap by averaging the last few heart beats, then the resulting number is used to modulate the RF signal like this:
- chest strap monitor’s RF carrier is at 110 kHz, 100% AM modulated
- a bit of 1 is made by a 3 ms ON (100% RF) followed by a 4.8 ms OFF (0% RF)
- a bit of 0 is made by a 7.8 ms OFF (0% RF)
The BPM data is constantly sent about 0.5 to 2 times per second. The delay between two data packets is unrelated with the heart beat. The structure of a packet is:
- one start sync bit with 5ms ON (100% RF) and 4.8ms OFF (0% RF)
- next 6 bits encode the chest strap ID (IDentification). The ID changes randomly each time the battery is disconnected. The observed IDs were all bigger then 48 (first two bits 11)
- the remaining 13 bits encodes the BPM.
This stream of data is received and decoded by the wrist watch, which then display one number, the BPM. Observed BPM displayed range was between 30 and 233. The watch displays the BPM no matter what ID the chest belt randomly picked.
I tried to look at the carrier waveform corresponding to a couple of different BPM numbers, by doing push-ups in order to accelerate the heart beat. My intention was to understand the correspondence between the last 13 bits sent by the chest strap and the BPM number displayed by the wrist watch.
Counting bits after making push-ups is not easy. I couldn’t figure out the encoding scheme.
Another more rigorous testing way was necessary. Instead of using
real heart signals, a signal generator (RIGOL DG4102) was used to
simulate the electrical signals coming from the heart. By contrast with a
real heart, the generator can produce any BPM number with high
accuracy.
The output from the signal generator was connected to the
two conductive rubber pads of the chest strap. An one wire loop antenna
was wrapped around the chest belt, and the received RF signal was
displayed on the oscilloscope (RIGOL DS1054Z).
Also, another signal was generated by the second channel of the generator, and was added as a grid (the magenta signal), to ease the task of counting consecutive bits of zero. Each magenta spike is now pointing to a zero or a one bit. The yellow signal in this capture is:
S 111001 0101000100011
Where ‘S’ is the Sync bit, ‘111001’ is the chest strap ID and ‘0101000100011’ is the BPM. For this particular signal, the wrist watch will display one hundred BPM.
By varying the period of the fake heart beat generated signal, all possible heart rates were browsed.
The following table contains the encoding bits sent by the chest strap for each possible BPM number displayed by the wrist watch.
If someone recognizes this encoding scheme, then please let me know, because I still can not figure out the formula between the last 13 RF bits and the displayed BPM number.
Oscilloscope Display Display (binary) 0010101110010 30 00011110 0010101111100 31 00011111 0011000010011 32 00100000 0011000010101 33 00100001 0011000011001 34 00100010 0011000011110 35 00100011 0011000100011 36 00100100 0011000100101 37 00100101 0011000101001 38 00100110 0011000101110 39 00100111 0011001000011 40 00101000 0011001000101 41 00101001 0011001001001 42 00101010 0011001001110 43 00101011 0011001100110 44 00101100 0011001101010 45 00101101 0011001110010 46 00101110 0011001111100 47 00101111 0011100100110 48 00110000 0011100101010 49 00110001 0011100110010 50 00110010 0011100111100 51 00110011 0011101000110 52 00110100 0011101001010 53 00110101 0011101010010 54 00110110 0011101011100 55 00110111 0011110000110 56 00111000 0011110001010 57 00111001 0011110010010 58 00111010 0011110011100 59 00111011 0011111001100 60 00111100 0011111010100 61 00111101 0011111100100 62 00111110 0011111111000 63 00111111 0100010010011 64 01000000 0100010010101 65 01000001 0100010011001 66 01000010 0100010011110 67 01000011 0100010100011 68 01000100 0100010100101 69 01000101 0100010101001 70 01000110 0100010101110 71 01000111 0100011000011 72 01001000 0100011000101 73 01001001 0100011001001 74 01001010 0100011001110 75 01001011 0100011100110 76 01001100 0100011101010 77 01001101 0100011110010 78 01001110 0100011111100 79 01001111 0100100010011 80 01010000 0100100010101 81 01010001 0100100011001 82 01010010 0100100011110 83 01010011 0100100100011 84 01010100 0100100100101 85 01010101 0100100101001 86 01010110 0100100101110 87 01010111 0100101000011 88 01011000 0100101000101 89 01011001 0100101001001 90 01011010 0100101001110 91 01011011 0100101100110 92 01011100 0100101101010 93 01011101 0100101110010 94 01011110 0100101111100 95 01011111 0101000010011 96 01100000 0101000010101 97 01100001 0101000011001 98 01100010 0101000011110 99 01100011 0101000100011 100 01100100 0101000100101 101 01100101 0101000101001 102 01100110 0101000101110 103 01100111 0101001000011 104 01101000 0101001000101 105 01101001 0101001001001 106 01101010 0101001001110 107 01101011 0101001100110 108 01101100 0101001101010 109 01101101 0101001110010 110 01101110 0101001111100 111 01101111 0101100100110 112 01110000 0101100101010 113 01110001 0101100110010 114 01110010 0101100111100 115 01110011 0101101000110 116 01110100 0101101001010 117 01110101 0101101010010 118 01110110 0101101011100 119 01110111 0101110000110 120 01111000 0101110001010 121 01111001 0101110010010 122 01111010 0101110011100 123 01111011 0101111001100 124 01111100 0101111010100 125 01111101 0101111100100 126 01111110 0101111111000 127 01111111 1000010010011 128 10000000 1000010010101 129 10000001 1000010011001 130 10000010 1000010011110 131 10000011 1000010100011 132 10000100 1000010100101 133 10000101 1000010101001 134 10000110 1000010101110 135 10000111 1000011000011 136 10001000 1000011000101 137 10001001 1000011001001 138 10001010 1000011001110 139 10001011 1000011100110 140 10001100 1000011101010 141 10001101 1000011110010 142 10001110 1000011111100 143 10001111 1000100010011 144 10010000 1000100010101 145 10010001 1000100011001 146 10010010 1000100011110 147 10010011 1000100100011 148 10010100 1000100100101 149 10010101 1000100101001 150 10010110 1000100101110 151 10010111 1000101000011 152 10011000 1000101000101 153 10011001 1000101001001 154 10011010 1000101001110 155 10011011 1000101100110 156 10011100 1000101101010 157 10011101 1000101110010 158 10011110 1000101111100 159 10011111 1001000010011 160 10100000 1001000010101 161 10100001 1001000011001 162 10100010 1001000011110 163 10100011 1001000100011 164 10100100 1001000100101 165 10100101 1001000101001 166 10100110 1001000101110 167 10100111 1001001000011 168 10101000 1001001000101 169 10101001 1001001001001 170 10101010 1001001001110 171 10101011 1001001100110 172 10101100 1001001101010 173 10101101 1001001110010 174 10101110 1001001111100 175 10101111 1001100100110 176 10110000 1001100101010 177 10110001 1001100110010 178 10110010 1001100111100 179 10110011 1001101000110 180 10110100 1001101001010 181 10110101 1001101010010 182 10110110 1001101011100 183 10110111 1001110000110 184 10111000 1001110001010 185 10111001 1001110010010 186 10111010 1001110011100 187 10111011 1001111001100 188 10111100 1001111010100 189 10111101 1001111100100 190 10111110 1001111111000 191 10111111 1100100100110 192 11000000 1100100101010 193 11000001 1100100110010 194 11000010 1100100111100 195 11000011 1100101000110 196 11000100 1100101001010 197 11000101 1100101010010 198 11000110 1100101011100 199 11000111 1100110000110 200 11001000 1100110001010 201 11001001 1100110010010 202 11001010 1100110011100 203 11001011 1100111001100 204 11001100 1100111010100 205 11001101 1100111100100 206 11001110 1100111111000 207 11001111 1101000100110 208 11010000 1101000101010 209 11010001 1101000110010 210 11010010 1101000111100 211 11010011 1101001000110 212 11010100 1101001001010 213 11010101 1101001010010 214 11010110 1101001011100 215 11010111 1101010000110 216 11011000 1101010001010 217 11011001 1101010010010 218 11011010 1101010011100 219 11011011 1101011001100 220 11011100 1101011010100 221 11011101 1101011100100 222 11011110 1101011111000 223 11011111 1110000100110 224 11100000 1110000101010 225 11100001 1110000110010 226 11100010 1110000111100 227 11100011 1110001000110 228 11100100 1110001001010 229 11100101 1110001010010 230 11100110 1110010000110 231 11100111 1110001011100 232 11101000 1110010001010 233 11101001
