Today we received the tensiometer which is kind of old school and we realised it would be hard to trick it so has it would work with the Arduino Card.
However, we advanced on the project, the connections that you can see on the picture below
We got a small problem for inputing the code on the card.
The next step is to input the code, then we'll check for the tensiometer which needs some physicals modifications.
End of the log
