Hackaday.io Hackaday.io
Sign up Log in
Plater: 3D-printer plate generator
Plater is a software that places some STL parts on your buildplate automatically. It handle nesting of the parts, doing the puzzle for you!
grgoire-passaultGrégoire Passault
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.2k views
3 comments
69 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 3
View Gallery
3.2k
3
69
26
Team (1)
  • grgoire-passaultGrégoire Passault
Join this project's team
  • Plater (source code & binaries)
  • Printing a robot in one plate (french)
This project was created on 06/03/2014
Description
When you release a 3D design, or browse some, you sometime have "plated" versions involving all the parts on the same STL. This allow to print complex things in a row, without human intervention. You can just sleep or go away and get back your design later.
However, creating the plate can be quite boring, and it's hard to make plates that will be compatible with all printer dimensions.
Plater is a software that can generate the plate for you, it can import STL files, with quantity and orientation, and it will try to create puzzle the parts to create at least plates as possible, given some parameters sucha as plate dimensions, parts spacing etc.
You can also export/import a configuration file (plater.conf) that contains the parts list with quantities and orientation on the plate. This way, the configuration file can either be released with the 3D design, that would make people able to generate their own plates using Plater, and the already plated STL can also be released.
Project Logs
Collapse
  • Releasing v1.0
    Grégoire Passault • 06/03/2014 at 06:47 • 0 comments
    The version 1.0 was released
    It can be used either with command-line tools and Qt+OpenGL GUI
    Source code and link to binaries available here:
    https://github.com/RobotsWar/Plater#plater
View project log
Log In/Sign up to comment
Sign up with Github
OR
dangerousfood wrote 05/15/2015 at 02:04 • point
Your project is awesome. How did you tackle the NP problem?
Grégoire Passault wrote 10/27/2014 at 10:09 • point
Thanks, any feedback would be appreciated ;-)
Albert Latham wrote 10/26/2014 at 22:58 • point
I am surprised that no one has commented. I may be getting a 3D printer tomorrow and so I'd love to give this a shot, especially if it has a command line portion. I look forward to trying this out.
The 2017 Hackaday Prize
A Collection of 3D printable parts for building machines and other mechanical creations from 2020 Aluminum Exstrusions.
Project Owner Contributor
2020 Al Extrusion Erector Set
avrAVR
Use a cnc or 3d printer to make rope!
Rope Making Machine
alexanderfhillalexander.f.hill
Hackaday Prize 2020
A turntable wich you can fully 3D-print, no extra parts needed!
Fully 3D-printable turntable
brian-brockenBrian Brocken
Reviving a set of headphones with some CAD work and 3D printed parts
3D Printed Beats MIXR repair
trysten-den-hartogTrysten Den Hartog
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Plater: 3D-printer plate generator", please tell us the reason.
Send message
Remove Member
