My MP Select Mini's heatbreak needs a new PTFE lining. The printer jammed while I was printing the latest revision of the JouleBox's base plate. It should be up and running soon, the new version of the JouleBox will be 2mm thick for additional structural stability especially where the two shells overlap.
