Another small plugin that allows viewing of my outdoor and indoor webcams (one turned off for this screenshot). The images stream MJPEG and the PHP script acts as a proxy server to stream to the outside world. Its capable of using password protected cameras. The page is then feed out the the internet using my authentication and HTTPS protocols even if the cameras did not support SSL or authentication.
This plugin can also be attached to any camera monitoring or recording service that supports MJPEG.
