So over the last few days i have been playing with HTML5 and CSS to work out the best interface options for how automation could function.
So far I am leaning toward a node style interface. Elements could be added with a right click menu that provides inputs, outputs and decision conditions.
I still have a lot of interface work before turning my attention to the back end.
i need to:
- Add a way to remove items. (right now you can only add them.
- I have text boxes but i think it would be good to have drop downs, maybe check boxes or radio buttons but i am not sure about that one.
- Create some Javascript that exports to JSON and sends back to the server on every edit. Should save the last 100 or so edits in a queue so i can add an undo button that works even weeks, months or years after the edit.
- Create a JSON standard for how elements are added, put this in the database so adding new plugins can add new inputs/outputs/conditions.
- The menu lists will be dynamic so i need to have an option for menu items to wrap around if they are more then 15 or so items.
Thoughts?
