compliant mechanisms
A project log for 3LE - linear laser light engine
a flat, modular and scalable light engine concept for stereolithography and its applications
helgehelge 03/26/2019 at 17:121 Comment
While most of my projects currently suffer from extreme dilution effects (priorities something something), the closed-loop installation of the lenses is more or less clarified and just needs to be put together and executed... but the hinge mechanism with the piezo bimorph element is somewhat undefined and not super satisfactory.
The current design assumes two light-weight u-shaped brackets with bushings and dynamic pre-tensioning. When using four piezo elements, possible movements are
* vertical movement (both pivot points moving up or down simultaneously)
* horizontal movement (both pivot points moving left or right simultaneously)
* tilt correction (pivot points moving in opposite vertical direction)
* pinching / preloading (pivot points moving towards one another)
While this is nice to implement automatic calibration that compensates for creep, sag and wear of the bushings, doing away with the intricacies of multiple bushings would have its charms.
https://www.compliantmechanisms.byu.edu/about-compliant-mechanisms
MasterOfNull wrote 05/03/2019 at 10:10 point
You could also scan the laser with acoustics.  The deflection you can get is really small, but that is about as close to solid state as you can get.  https://en.wikipedia.org/wiki/Acousto-optic_modulator
