So last night I etched my first PCB is about 20 years.... scary...
Its not gone perfect.y, I used the toner transfer method on some baking paper. But toner cracked and flaked a bit and didnt iron on perfectly... So its a little messy and one or two traces might be broken, I can fix those with some solder.
But its a functioning board so should work for the prototype.
When I make the final build of this version of dash ill make a cleaner board.
Anyway heres a couple of pics of the thing.
Mangus Tiranus
