So far I've gone for the STM32F446VET6 a LQFP100 Cortex M4, I switched away from the LQFP64 because I wanted the option of using the FMC for external RAM, probably muxed PSRAM.
I use Eagle for these type of layouts, and I don't have a part already for this chip, so time to make one, I have older videos on YouTube showing a video of the BSDL, but this time i'm going to do it a bit differently and use a new service I recently came across.
I'm going to create the part from a BSDL file, which is at BSDL for STM32F446 a BSDL file is a Boundary Scan Description Language file, unzip this file to a folder somewhere.
Load Eagle, create or add to a new library, run the ULP make-symbol-device-package-bsdl.ulp
Load the LQFP_100 BSDL file for the STMF446.
I selected quad, so that will be the symbol layout as it'll appear inside the Eagle schematic editor. I also added a Variant name as LQFP100Next go to the Package tab, chose the layout. The Parameters are in the STM32F446s datasheet in the mechanical selection, most of the parameters will be listed in a table. Copy them over and select the style of package, save config and accept parameter
Go back to the Make Page and click Ok in the bottom left.
This will appear
Quad style layout with pins on all sides, some people prefer to split it up into groups, you can edit this in the Symbol editor.Or you can use SnapEDA to find the package and add it, I happen to know already that SnapEDA doesn't have this symbol in Eagle yet, but it does have a LQFP100 14x14 footprint. Otherwise we could have just gotten it from there in the first place.
If you haven't already make a SnapEDA account, and setup Eagle to use it.
Login to SnapEDA and go here Eagle Plugin, follow the instructions which is basically copy the all the files except the icon to the eagle ULP folder and the png to the eagle bin folder. Open the eagle.scr file (in the scr folder) and add in to the SCH/BRD sections
'[snapeda.png] SnapEDA : Run snapeda.ulp;'\
so it looks like
BRD:
MENU '[designlink.png] Search and order : Run designlink-order.ulp -general;'\
'[pcb-service.png] PCB Service : Run pcb-service.ulp;'\
'[idf-3d.png] Export to IDF 3D format: Run eagleidfexporter.ulp;'\
SCH:
Grid Default;
Change Width 0.006in;
MENU '[designlink.png] Search and order {\
General : Run designlink-order.ulp -general; |\
Schematic : Run designlink-order.ulp; \
'[LTspice.png] LT Spice simulation {\
Export: RUN ltspice.ulp /E; |\
Export Setup: RUN ltspice.ulp /E /S; |\
Export Group: RUN ltspice.ulp /E /G; |\
Import: RUN ltspice.ulp /I; \
Start Eagle again, and create a new schematic.
At the top of the eagle sch/brd editor you should see a SnapEDA logo, click it.
In the lower text entry, type in the part number you want. stm32f446vet6 and hit Search.
Select the correct entry and then click on "Download on SnapEDA", you can also do this on their website. It'll open the browser.
This will take you here, and currently it just shows the footprint, which is all we need at the momentDownload footprint, select Eagle
SnapEDA will now download a lbr file for you. the procedure is documented here
https://www.snapeda.com/about/import/
Load the newly downloaded .lbr into Eagle.
Double click the package listed under Package, the QFP50xxxxx etc
Now we have a much better package layout, so lets grab it and move it into the library we created with the BSDL earlier.
Use the group, command, i usually just type group<enter> into the eagle cmd line, drag select with the mouse the whole package and use cut(again i type cut into the eagle cmd line) , right click and select "Group: cut" the whole package is now in the cut buffer.
Go back to the BSDL created library with the bad package, without exiting Eagle.
Go back to the Device screen by selecting the LQFP100 device.
From the Eagle menu bar select Library, Package and make a new Package that's called LQFP100
Now paste the Package (ctrl +v) and click to place it. Remember not to leave Eagle after you did the group/cut on the lbr downloaded from SnapEDA, otherwise there will be nothing to paste.
If you don't have anything to paste, reload the .lbr downloaded from SnapEDA and do the cut again. "group, drag select and type cut, right click, select "group: cut" from the popup menu".
Once it looks like the following,
Again go back to the device screen, and right click under Package then select New.,, or click the New Button.
Give it a new variant name that doesn't already exist.
It should be a different variant name from the one that is already there, you can rename the existing one to LQFP100_BAD or something before you create the new variant, don't delete the bad package yet. I Ended up just calling it LQFP100, not LQFP100_CORRECT, sorry about that. So look for LQFP100 after this.
You should have something like this, the yellow exclamation means the pins haven't been connected yet. So we will do that next.
Click Connect, or right click on the LQFP100 (the one with the yellow exclamation mark) variant in the Package list
Now we'd normally tediously go through each of these and make sure each Pin was connected to the right Pad, however the BSDL script already did that for us in the bad Pad layout of LQFP100_PACKAGE variant. So Where it says "Copy from" select the drop down and choose the existing variant.
And all the Connections will be made for you. Now click OK
Now delete the bad Package Variant, right click on the LQFP100_PACKAGE and hit Delete
Now you should have this
Now all you have to do is give it a useful description , click on the Blue Description line and you can add as much info as you want, data sheet link etc. It uses HTML
<B>STM446VET6<P>
<A HREF="http://www.st.com/content/st_com/en/products/microcontrollers/stm32-32-bit-arm-cortex-mcus/stm32f4-series/stm32f446/stm32f446ve.html">Data Sheet</A>
<p>Core: ARM® 32-bit Cortex®-M4 CPU with FPU, Adaptive real-time accelerator (ART Accelerator™) allowing 0-wait state execution from Fl ash memory, frequency up to 180 MHz, MPU, 225 DMIPS/1.25 DMIPS/MHz (Dhrystone 2.1), and DSP instructions
Memories<p>
Something like that, save the library and you're ready to add it to your schematic.Of course you should print out the pads, check the sizes and depending if you want to do reflow or hand solder etc adjust them etc. Make sure the Pin names match as the OEM sometimes makes mistakes in the BSDL files.
That is it for now, next we'll look at using some of the PCB Assembly services and how to go about minimising the costs involved by using as many of their predefined parts as possible.
