One-sided PCB
A project log for Servo Breakout for WeMos D1 Mini
Connect servos to your ESP8266 dev board.
dehipudeʃhipu 11/30/2016 at 14:150 Comments
Looking at the design from the last log, I thought "Hmm, if only I had some more room on the sides for the ground and power lines, I could make this a single-sided PCB". Turns out I was wrong.
This is my best attempt at this. See that highlighted SDA line? If only it wasn't there, or I could fit it somehow next to the SCL line, everything would have been just fine. The track next to it would take it place, and the power rail could get a connection on top, where that track is now. Alas, there is no way to do that without a jumper cable.
Oh well, a jumper can't hurt, can it?
