In the previous Project Log, I talked about the EEG REM Detection algorithm (Imtiaz et al.). In this log, I will talk about the implementation of the algorithm in C++. Note, for the OpenLD software, I will be using Qt C++, due to its extensive cross-platform support and ease of use.
Implementation of REM Detection
I will list the C++ code along with its corresponding formula, which are explained in depth in the previous Project Log.
SEFd (Spectral Edge Frequency difference)
SEF(x) where x in the Percentage of Edge Frequency:
#define FREQ_TO_BIN(x, N_FFT, Fs) int(x * N_FFT/Fs)
#define BIN_TO_FREQ(x, N_FFT, Fs) int(x * Fs/N_FFT)
double remDetect::SEFx(double *spectrum, int x, int f_Start, double sum_SEF)
double sum_fft = 0;
for (int i = FREQ_TO_BIN(f_Start, m_size_fft, m_Fs); sum_fft < ((double)x) / 100.0 * sum_SEF; i++) {
sum_fft += spectrum[i] * spectrum[i] * ((double)m_Fs) / ((double)m_size_fft);
return (((double)i) * ((double)m_Fs) / ((double)m_size_fft));
SEFd: the difference between SEF95 and SEF50
SEFd[epoch_Counter] = SEFx(spectrum, 95, f_Start, m_SEF_sum) - SEFx(spectrum, 50, f_Start, m_SEF_sum);
AP (Absolute Power) and RP (Relative Power)
Absolute Power
double remDetect::absPower(double *spectrum, int f_Start, int f_End)
double sum_fft = 0;
for (int i = FREQ_TO_BIN(f_Start, m_size_fft, m_Fs); i <= FREQ_TO_BIN(f_End, m_size_fft, m_Fs); i++) {
sum_fft += spectrum[i] * ((double)m_Fs) / ((double)m_size_fft);
return ((double) 20.0 * log10(sum_fft));
Relative Power
double remDetect::relPower(double *spectrum, int f_Start, int f_End)
double ratio_spectrum = 0;
ratio_spectrum = absPower(spectrum, f_Start, f_End) - absPower(spectrum, 1, f_Max);
return ratio_spectrum;
Decision Tree for REM Detection
int remDetect::evaluate_REM_Epoch()
// If the SEFd value is bigger than the specified minimum
if (avg_SEFd > m_min_SEFd) {
// If the averaged Absolute power is smaller than specified maximum
if (avg_AP < m_max_AP) {
// If the averaged Relative power is between the specified interval
if (avg_RP > m_min_RP && avg_RP < m_max_RP) {
// REM DETECTED :D
return 1;
} else return 0;
} else return 0;
} else return 0;
Sources
Imtiaz, Syed Anas, and Esther Rodriguez-Villegas. "A low computational cost algorithm for rem sleep detection using single channel EEG." Annals of biomedical engineering 42.11 (2014): 2344-2359.
