- or at least they make any buttons at all.
My Printrbot (pictured above) has not had an easy life. Almost from the day it arrived as a kit, I've been ricing (in vain) to achieve lofty goals like queue based 24/7 printing. And in response it has spent more time than not being broken or mid-upgrade. Over this summer I decided to rip out a lot of the crazy stuff and try to get back to nice, reasonable working order. It's going well, but there's still a lot left to do.
I'm a (self-proclaimed) terrible 3D printer operator. It seems as though endless hours slip away as I tune and calibrate, only to arrive at prints that look about as mangled as the first ones. After three years of owning one of these dang things, I still feel like a novice. If I'm going to make this printing-a-lot-of-buttons thing work, the printer and I need to find some common ground. To that effect, there's a lot of incremental changes I want to implement:
- The printer goes to work with me
- Takes up too much room at home, and my office is more conducive to keeping things tidy.
- Done!
- New base and scaffolding
- Just for aesthetics mainly.
- Done!
- Add auto-leveling
- Is a mess that needs a separate log post on its own.
- Done!
- More lighting
- I've learned that good visibility while working on these things is key.
- I have aluminum and led strips, just need to wire it up.
- Calibrate for PET-G
- It's the future, baby.
- Finish wiring external stepper drivers
- Probably the largest task, may require custom PCBs
- Make all external wiring easy to detach
- Being able to unplug the printer and physically move it is super underrated.
- Wire up loss-of-filament detector
- Will pause prints for me.
- Rebuild electronics panel
The idea is for the printer to remain usable in between each task, so it can continue to support Clunke development.
