I have uploaded a short video where the toniManero embedded web interface is used to control PWM outputs that are controlling some bulb lights by means of the analog interface pwm.mosfet.driver.230vac.pdf.
I also mention the system automation capability using RPC commands. There are some examples here:
https://github.com/oskrs111/pimcw/blob/master/release/arm/crontab.template.sh
