Because of the high number of sensor inputs and the low number of input ports on the Arduino, I have purchased a parallel-in serial-out (PISO) shift register which passes the digital sensor data as an array to a single Arduino input. The Arduino built-in clock is being used as the clock for the flip-flops in place of an external crystal oscillator or 555/556 timer IC.
