I don't know why I did this. But you could use this to get better insight into your water bill. I would not suggest this if you happen to live with other people, however.
Logging Flushes to the Cloud
Idea: this should be able to detect if it's taking too long to refill the tank. It should then alert, or even jiggle the handle itself (though I'm not handy with servos).
I've completed a prototype, but the following needs doing:
Here's the current code:
#define SWITCH_PIN 3
void setup () {
attachInterrupt(SWITCH_PIN, flush, FALLING);
void flush() {
Particle.publish("flush");
void loop () {}
I'll post the link once I've got a more permanent solution (and fix some of the triggering issues)--right now it's just running on a power bank.
Where's the website?
