The variation of the nasal
temperature is measured accurately using the MLX90614
noncontact infrared temperature sensor which is pointed to
the nasal passage.
The sensor is smaller in size and
comfortable when compared to nasal thermistors. As the
child exhales, the nasal temperature increases which are
picked up by the Infrared (IR) temperature sensor. The data
is read at high speeds by the Microcontroller over the I2C
bus.
The sensor also detects ambient temperature which is
used for calibration to identify threshold. The samples are
compared with each other and the peaks are found. The
internal timer is triggered to find the peak to peak time
duration from which the respiration rate can be accurately
found.
I've recorded some raw data from the MLX90614 sensor and had the data posted to plotly.
Here is the raw respiration data I recorded for 3 mins.
