Photoplethysmography (PPG) and Pulse Oximetry (SpO2)
are carried out by a single sensor which is used to measure
reflectance of three LEDs of different wavelengths. SpO2
is found by measuring the reflectance of 650 nm light in
comparison with 940 nm light. Heart rate is measured by
PPG wherein the change in blood volume is found by
measuring reflectance of 850 nm light. The measurement
of vital signs by placing sensors and LEDs behind the
earlobe has been validated by previous work.
The
Si1143 I2C light sensor was chosen for its small size and
cost. The presence of an integrated amplifier and Analog to
Digital Converter (ADC) has resulted in a lesser Bill of
Materials (BOM). The Si1143 light sensor also has inbuilt
LED drives which allow easy control over three LEDs. I'm currently toying with the MAX30100, Will post the results here shortly.
Here is the heart rate data for 3 mins.
Here is the SpO2 data for 3 mins
