Hackaday.io Hackaday.io
Sign up Log in
DHT12 AM2320 Nokia 5110
DHT12 and AM2320 on a Nokia 5110 with WeMos D1 mini running MicroPython ESP8266
mike-causerMike Causer
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3k views
0 comments
12 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 0
View Gallery
3k
0
12
4
Team (1)
  • mike-causerMike Causer
Join this project's team
  • MicroPython ESP8266 DHT Nokia 5110
Software
ongoing project
micropython ESP8266 dht12 am2320
Related lists
D1 Mini
Project that use the D1 Mini ESP8266 board. Also shields for it.
This project is submitted for
  • ESP8266 Micropython Contest
This project was created on 08/28/2016 and last updated 10 years ago.
Description
Two new MicroPython libraries for the DHT12 and AM2320 temperature and humidity sensors.
Components
  • 1 × WeMos D1 Mini $4.00 USD on AliExpress
  • 1 × Nokia 5110 module $2.10 USD on AliExpress
  • 1 × Breadboard 400 point $1.02 USD on AliExpress
  • 1 × Jumper wires $1.72 USD on AliExpress
  • 1 × DHT12 $0.92 USD on AliExpress
View all 6 components
Build Instructions
Collapse
  • 1
    Step 1
    Detailed instructions on the GitHub project page.
View all instructions
Log In/Sign up to comment
Sign up with Github
OR
Monitor temperature and humidity over wifi.
Project Owner Contributor
MQTT Temperature and Humidity Monitor
liz-corsonLiz Corson
ESP8266(ESP-12F) WiFi temperature and humidity meter
ESP8266 WiFi temperature and humidity meter
pnoxiPnoxi
A Wifi (Homie-ESP8266) enabled temperature sensor with touch control (for set-temperature)
Touch Thermostat
ian-hubbertzIan Hubbertz
The 2015 Hackaday Prize
Monitor the temperature of your baby over the night and sleep peaceful, and also over the internet, even when you are away from home
Remote Thermometer For Your Babies (babyTherm)
eduardo-zolaEduardo Zola
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DHT12 AM2320 Nokia 5110", please tell us the reason.
Send message
Remove Member
