Super easy Hack with HP printer PSU
Powering an HP f2480 with a HP PSC2350 PSU
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
this is the easiest hack possible but I had to share it just in case.
Short story is I had a HP F2480 around with a missing PSU.
I purchased a HP PSC2350 PSU for 5 euros since it looked very capable (more Watts, same voltage and same connector ....but grey)
I plugged in but nothing happened. so I took my multimeter and find out that the 1st and the 2nd pin were giving 32v but the 2nd and the third were giving 16v (not expected by the printer).
So I simply cut the third wire and insulated it and ...that's it the printer is now working great ! PSU Hacked !
