OXYnhale is an air-filtering wearable mask designed to track the air pollutants present in the user's environment in real-time and filtering the air passing through the mask to the user accordingly.It's a misconception among users that once you wear a gas-mask you're safe. What's interesting is,that in a lot of situations (involving heavy amounts of air-pollutants and particulate matter in the user's immediate environment)wearing the mask does little damage to the air finally reaching the user & the user,unaware of this is exposed to these harmful gases for a longer duration.
Using an array of gas sensors to get an idea of the user's environment,the device filters are controlled.
This data,is then transferred to the mobile interface & besides being added to the air-database is compiled to give the user a detailed concentration analysis. In areas with toxic pollutant concentrations,both the mobil
