Update: Most sensors readily available
A project log for Raspberry Pi Home Med Lab Repository
I am actively adding components in 2016. Starting with the Centrifuge
tlankford01tlankford01 08/18/2014 at 12:520 Comments
It has been a while since I have posted to this project but there have been several exciting developments along these lines since the first of the year.  There are several kickstarters for different spectrometers.  However, we are getting ready to use Colormetrix smartphone app to work with standard testing strips and viles and a program for the smartphone.  This should make for a simple way to do blood, urine and saliva lab tests.  We have also stumbled across the e-Health sensor that will take care of most everything else on the above list of testing parameters that we set out to accomplish.  I will update soon as we begin to work with these items and see how they integrate.  We may need to do some software updates and integration.  We will definitely be building databases in the server to record information.  Thank you for following and hopefully we will have some results to post before too much longer.
Rich text editor
