3D Printed Case
A project log for Coin Cell Powered Temperature/Humidity Display
Using an ePaper Display, investigate getting the lowest possible current usage from an STM32L0.
kevin-kesslerKevin Kessler • 05/25/2018 at 14:32•0 Comments
While I'm waiting for parts and a PCB to do some testing with a boost converted, I designed a simple 3D printed case. It's got a magnet glued in its back so I can stick it on my metal cabinet at work.
I designed the case in OnShape, and the model is located here.
