Sometimes smaller is better. Thanks @Thomas for eForth on STM8. I've added the files to this project where I have tested the concept of using STM8 running eForth to be the controller for the RB3DP. The forward and reverse kinematics routines are tested, and a few GCODE commands are implemented. Stubs are used for actual actions, with text echo of internal commands.
Based on this test, RB3DP will accept GCODE in millimeters and have a maximum size of about 60 meters (the 16-bit integer maths maxes out at 65.535 meters).
Now to put it all together on ESP14 (which is STM8 with ESP8266).
Oops. Forgot to handle unused part of line being read. Updated GEV to consume and throw away unread comments at ends of lines.
: GEV ( -- )
NAME? IF EXECUTE ELSE DROP THEN
0 PARSE 2DROP ; \ bypass rest of the line
Now the code has read and processed a GCODE file of over 1MB created by Cura, just bypassing anything that is does not know how to handle (i.e. handles G1 and G0 lines and ignores the rest!!) @Thomas FYI
