I wanted to add an Isolation switch to my truck. I didn't want the terminals at the bottom to com into contact with any of the body of the truck (I don't like fires). I also did not want to cut a hole into the body of the truck for the switch so I designed this Switch housing.
Details
With this housing I can fix my isolation switch directly to the battery box.
Files
bat iso switch box.stl
STL file for printing
Standard Tesselated Geometry -
237.48 kB -
04/14/2018 at 01:34
I used ABS for this one as temperature in a automotive environment is not for the like of PLA. No rafts or supports needed. 50% fill. 3 perimeters for top bottom and sides. Very little cleanup needed.
