IoT System to control 433 MHz RC power sockets, PIR sensors, Door Sensors and much more. To start is required a 433mhz transmitter and receiver, a connected Arduino with the iot-433mhz sketch or directly with capable hardware like the Raspberry Pi.
Some features:
- Multi-platform (Windows, Mac OS X, Linux).
- Basic Authentication.
- Intuitive API & WebHooks to build your own interface.
- Built-In Material design cards-based template.
- Real-time UI refresh.
- Detect Radio Frequency codes (433mhz).
- Generate Cards and assign it to your rooms.
- Control RC power sockets, PIR sensors, Door sensors and much more.
- Telegram Bot for alarm notifications.
- Totally Open Source & Open Hardware.
Its interesting work on IoT. If it would help you we are from Wia,Dublin and may be you can refer the our tutorials to give it a try http://blog.wia.io/how-to-publish-an-event-using-wia-for-nodejs
